1 - 3 of 3 Posts
96 civic hatch
the issue is i had my jdm d15b running in my car with no cel's then the #3 piston dicided to leave the party with the help of a little boost.So i build up a vitara z6 bottom end starts up get it idling perfect but its throwing cel 1 which is my #1 o2 sensor.I triple check everything disconect battery and still throwing the same code i just cant figure out why i would be throwing this code when i was throwing nothing before everything is the same as my previous set up.
Did you replace your oxygen sensor? The reason I ask is because the 1 cel is for an oxygen sensor malfunction. If you are using your old sensor from the old setup you may have damaged your sensor. Have you properly diagnosed the oxygen sensor circuit?
96 civic hatch
yes i am using the sensor out of my old setup it only has like 1200km on it so i figured it would be fine and my wideband o2 sensor is still working fine
1 - 3 of 3 Posts
