ok, so after work today I was running a couple of errands. I was leaving a parking lot when I saw my CEL come on. I'm thinking, great, I was just coasting at 7 mph in a parking lot and something on my engine gets fucked up. so I pull over and check a few things. first oil, it was full, just had it changed last week. no problem there. no oil leaking from engine that I can see. ok good.
next I think, well maybe it's my o2 simulator is malfunctioning or fell off and is sitting in the road somewhere. so I get out the jack, and crank the car up crawl under there, and yep it's still there. so I crawl back out and put the key in the acc position then crawl back under there. the o2 sim. light is flashing just like it should be.
next I check the battery, because I remember that during my oil change they said it was loosing power and should be replace in the next couple of months. so I look at the little light, and I can't see it. great my battery is about dead.
so I go and have it check a couple of miles down the road at O'Reilly, the say the battery is putting out 290 CCAs and that the alternator is charging it up to over 400. so I replace the battery there in the parking lot. start the car up, rev it up a few times to about 6k. and no CEL. So I proceed to drive home 8 miles down the highway taking all the way through 3rd gear (90) vtec kicked in and no CEL.
so to make this long story short, did my almost dead battery cause the CEL? I know that when I removed the battery I reset the ecu, or at least cleared it out.
if it did cause the CEL, why? and why didn't the Battery light come on?
thank you for your help.
edit: if it helps, the car is a 99 ex d16y8, stock ecu
