so i removed the charcoal canister and made it into a catch can. had some pcv parts and the stock valve cover intake bit laying around so i put them to good use...i think. tell me if this will function properly.
bottom tube is from the charcoal canister, side tube is connected to black box
this is connected to the valve cover
how it looks from above
should i add the filter material between the tubes?
this is from a 2nd charcoal canister
how it will look finished.
let me know what you think!
ministry of mayhem!
93 honda integra
hey, not a bad idea dude.
rep for you.
huh?
Doe's it work?...cuz if so, then right on...!
'91 CRX Si
:td: :td:
two thumbs up for ingenuity.
do you have the bottom hole plugged or is the oil just gonna drip out?
right now the oil will just drip out, ive driven around boosting up to 10lbs and im not seeing too much in the way of blow by, some particles on the bottom but the filter materials are keeping anything from getting to the valve cover. im thinking ill plug it up to see whats being caught. this is the cheapest and best looking catch can i can think of, all oem parts and its already got a mounting spot:bigok:
Civic Si hatch EH3 -
i did the same thing... didn't post here cause i think i would be flammed lol..
but i removed the filters inside de canister!
however i leave it in the stock place... low profile FTW
