1 - 7 of 7 Posts
99hatch,99coupe,crv
I have one -10 out of my valve cover and one -10 out back of block, i heard its not good to run the one out of the back of the block because thats where the oil drain back from the head is, getting tuned in 2 weeks wondering what people have on there set up is, thanks
racist-bigot-sexist-homophob
There are tons and tons of threads on this. Did you try searching?
do you really think you haave enough blow-by to constantly keep a -10an line filled? or could the drain back be doing two jobs?
ask your self and use common sence
99hatch,99coupe,crv
I have the Speedfactory valve cover and it has -10 fittings just wondering if it is good to use the line in the rear of blOck or not to use it
1 - 7 of 7 Posts
