C
yea there are differences.
i tried using my brother's rex cat on my 93 civic and the rex cat was a lil shorter
Wow thats wild, because i currently have a 96 EX converter on my CRX, and it fit perfect?? But i need to get a cat for the CRX, so i can put my Civics back on, and i got one from supposivly a hatch, and its too short, like 1 inch shorter than it needs to be.
My CRX has a header on it, and im not sure what year its from, i think that the Pre EF's have longer Header pipes, on it, so that way the cat is shorter??? maybe thats it.
W
civic4ges said:
Ok...so a 96-00 civic lx cat is the same as a say, 95 si?
Wrong
no i was joking about none-meaning not to run one :p, but i see no one has a sense of humour now a days
C
dude i tried it between the 88-91 crx with the 92-95 civic, there's a difference in length, but it's not by too much. is that good enough to convince you it's not the same.
it might work if you pull or push the exhaust a little depending on if your cat is shorter or longer.
