1 - 3 of 3 Posts
civic coupe
im looking at a c.f hood localily to buy it. good clear coat a couple small chips but for 60 bucks what the hell right! its has 2 stripped holes and 1 broken bolt? how hard/easy of a fix is that?
the broken one i can just drill it out and replace i would think?
the stripped ones i may try to back them out and go with a larger bolt?
any help will be good!
91 CRX Si
You could always go with hood pins at all 4 corners. i've seen it done. Other wise, I'm not sure what to do. For $60, I'd at least use it as wall art in the garage or something...heh.
Mostly the 91 CRX
give it a shot is it don't work then use the wall art idea.
Reactions: 93 red ls
1 - 3 of 3 Posts
