Ive searched the forums for similar topics, couldnt find one so i created a new one.
My current engine is a carbureted D13 making 82 hp in the crank. prospect engine to be swapped is a D16Y8 from a 97 EK Civic, i will be getting the engine, tranny, ECU, Harness & Axles.
From what i know, i need to source the following to proceed with my project:
Now my Q is: what are the other things i need to get? What do i need to prepare?
btw, the car to swapped is not a civic. its an asean car that honda built to cater for the market. its called a city. so there's some differences with the suspension and brakes. but basically, installing another D series is a easy as 123.
It's quite a daunting task on a carbed Civic, and that is a car that came with EFI from the factory... let alone a City that never had an EFI version. You'll make more power if you run the y8 with good carbs (Weber, Mikuni, Dellorto... even bike carbs on the runners of a hacked up stock manifold). It'll be not unlike an ITB setup, but without the hassle.
on a carbed eg hatch, its easy, just get an eg efi fuel tank etc,
now on a honda city? i see an easy option is to convert ur carb tank into an efi tank by means of installing an inboard efi pump... ive seen it done alot of times and, it is fine..
Unless you go boosted, I see a set of decent carbs as the better option tout court. (excuse my French, I don't know how to express that in English... nor in Dutch or any other language, come to think of it :noway: )
You could even get a set of Keihin CV carbs off a D14a1 or D16z1 and use those for a cheap solution. I doubt they'll lose you power, since the D16z1 makes just as much power as a D16a6, and people put z6/y8 heads on the z1 too with good result.
why? because i think its a better engine to start my "tuning"
i only tried to do the "simultaneous" trick on my stock carb. yes i believe just swapping a weber or dual keihin carbs will boost the hp easily,
no real plans of racing, just my opinion; in case i decide to gradually tune the 1.6 engine to my liking, isn't it a better platform to start compared to my carbed 1300 cc motor?
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Honda D Series Forum
