1 - 7 of 7 Posts
i made an all motor d16z6 and have swapped it in my 88 civic(d12b1) the jap version...now the checklights givin me a map error....how the hell should i remove it i tried everything...before the car started and whooped to 5k rpm then i unplugged the map nothin happen then i unplugged tps nothin happen then i unplugged iacv the car finally chocked and died down...then the check lite gave me a map error...i dun know wat to do next iam fed up of this shyt....help me out ppl...
Discussion Starter · #4 ·
iam using a p08 chipped ecu for d16z6......yes i connected the pins da way it said VGO on the map...v for voltage G for ground and O for signal....now the car is not starting up and iam soo fkn worried its my only ride..now i have to walk for 2 miles to get my buss and go to my coll...iam soo tired of this....soo u guys say its the map ..okay i'll get the map asap ...it is very exp it costs arounnd 270 here....
91 hatch
0r if it's not the map maybe your dizzy does it turn over atleast just not firing had a similar problem check for spark all the way thru your ignition system. plugs, ignition coil, igniter unit, and cap & rotor. i drove mine around for about an hour ,and it then it would'nt start. check your timing also
p.s. i found a map sensor on ebay for 20 bucks oem
Discussion Starter · #7 ·
shppin charges are way more than 20 ...that 20 is gonna cost me a 100....lol umm dizzy?...
1 - 7 of 7 Posts
