So I have a 95 Civic with a d16y7 went to change the steering wheel when everything was put back together the car won't crank the position lights start flashing I can hear a relay click as they flash as well there's a little red blinking light inside the car but I get no ignition the car won't start won't do nothing that fuel pump goes on I think I can hear it turn on but the car won't crank at all any help any advice would be helpful please also if I tap the steering wheel or hit the dashboard or anything the lights will start flashing again until I disconnect the battery
Sent from my SM-N920T using Tapatalk
Sounds like you have an alarm in the car. You need the key pad or take out the alarm if you don’t have the key pad. You will need to splice wires together if you take the alarm out.
why this was in "d-series cookbook" is beyond me
Discussion Starter · #5 ·
Yeah I think so I just can't find where the alarm is that's the bitch
