1 - 2 of 2 Posts
I drive a 92cx with a d16z6 swap. I drove to school this morning, and everything was normal; drove fine without issue. On my way back home it was still driving fine but at the end of 1st gear it sounded like the engine just quit. I put it neutral and rolled into an empty parking lot close by.
Under the hood everything seems fine; all the belts are okay. I called a friend and he couldn't find anything wrong either... so we headed home.
Could a bad alternator distributer cause this?
what do you think could be wrong?
will the car start up again ?
i had ,and still have a problem like that it will stall in rpms above 4000 ...
im waiting on a new dizzy to see if it the problem ... and have you checked for any cel's?
if so i think you might have the same problemas me ... code 15 ignition output signal .
jusr check for codes
1 - 2 of 2 Posts
