1 - 3 of 3 Posts
Everything was fine and i was just cruising down the road. When i came up to a stop sign the car died and would not start back up.
I check my timing and changed the dizzy with new plugs,new wires,tried starting fluid,tried a different ecu.it is getting gas and spark and compression but it wont start. Like i said it just shut off and wouldnt start back up,yet it was driving perfect before that.
Any ideas??
Ive heard the ignition switch may have gone bad,but the cluster still works properly,the fuel pump still primes,the starter still engages,but it wont start.
10 second daily driver :)
confirm its getting fuel at the injectors, confirm its sparking all 4 cyl and properly, confirm timing belt has not jumped teeth.
1 - 3 of 3 Posts
