89 hatchback
I have an ef hatch with a turbo y8 in it. Td04 turbo 440cc injectors walbro pump moto 2.5bar map. My problem is everytime the car sees boost its fine but when i let off the gas and idle the car runs shitty like its going to die and i gatta turn the car off and back on to get it to run good again. No cels nuttin. Any ideas of whats up?
Integra
did you try to adjust the idle speed or iacv need cleaned?
89 hatchback
Iac is good
Tuned on crome
11.5:1 ratio
Stock ignition stock y8 distributor
Its only after boost after i let off da gas idles crappy and has hard time rev below like 2k rpm
