1 - 20 of 33 Posts
Ok so I recently bent a valve and broke a guide on my head, so I had that fixed, put it all back together and now here's my problem:
I'll answer the questions I've asked myself first
How do I know this? When I pull off #4 spark plug wire (by the dist) the whole car dies.
1. Yes it has gas
2. Yes the injectors are wired properly
3. Yes I tried rewiring them like 10 times
4. Tried with resistor box
5. Tried with inline resistors
6. Yes I tried swapping them with different injectors
7. Yes it has spark
8. Yes it has compression
Ideas?
www.rifftrax.com
timing?
and there is NO way it is running on only one cylinder. you need to pull each plug wire one at a time and see which plugs MAKE NO DIFFERENCE then you know what cylinder is the problem.
Confirm mechanical cam timing. What are your compression readings? Where do you have spark? Confirm spark at the plugs themselves. You can confirm fuel by pulling the rail off the manifold and keeping the injectors on the rail and placing a little cup underneath each injector.
timing?
I've pulled each plug, when I pull the last closest to the dist the car dies completely, pulling any other plug makes no difference. and it's not really running.... you have to stay on the gas to keep it alive, it won't idle.
I'll have a friend come over and check the timing, compression readings were 120 accross, spark is at the plug
Even if it is the rings, it should still run.....
It'll just burn oil
not true, if your rings are not creating compression you will not have a running car. And to add to that, if your valves are leaking as well, then you have a major compression loss. Do a wet and dry compression test and report back.
Im going to call this bad timing.
you said only one cylinder was malfunc due to your valve problems? sounds like a worn out engine with maybe two dead cylinders
if all cyl. are getting spark and fuel, and its not starting, then it has to be timing or major mechanical problems with your motor
Curious George
4 bangers shouldn't start with only one cylinder, will make exhaust backfire or intake backfire firing order is wrong. If the injector pulse isn't at the right time, it might start, intake port can keep the gaz a short time in it before the next opening. But I don't think it run with only one cylinder.
It's often what we messed with, and I see that you've played enough with injector wires.
1: Watch if the firing order is in right order. with another running honda, or with valve cover removed and dizzy cap removed to see each cylinder stroke and fire time.
2: Once right, maybe some people here will throw me tomatoes, but it works: put four 12 volt bulbs on each injector plugs (unplugged), and try to start if you have voltage to each injector connector. If not It could be you roasted your ecu by plugging wrong injectors (high or low impedance) without resistor box.
3: If you have 4 bulb working, remove all 4 spark plugs and spark wires (let the spark plugs to the wire, it will be your fire signal), Align them with each cylinder and bulb, and ask to somebody to start, you will see bulb lightening fast JUST before the spark, if not, wrong wiring connection. Engine is not turning that fast, you should see that.
It could be a first diagnosis, perhaps it won't work if trouble is somewhere else.
I think it would be impossible for a motor to run on JUST 1 cyl (in 4 cyl) for a standard 4 stroke motor. But hey, if you did the trial and error to find this, im very surprised.
it is prob running on 2 cylinders when u pull one of the firing cylinders its dying cause it has noting to keep the motor stroking
i say its either wires are on wrong or you fried the injector drivers on the ecu..
so look at my pic and you will see the right wiring order
or try a new ecu
how are you testing your spark
lol i forgot about this one the guy wouldn't listen , but when he did it cranked right up
he has the wires wrong i wrote the numbers to show the right way thank you get back at us when u try it
did you check your rocker to valve gap. if its a little to tight the valve will stay slightly open and losing all compression in that cylinder.
i know this cuz i've done it and almost ripped out all my hair trying to figure out what the hell was wrong. so i pulled the valve cover and started checking and sure enough two valves were to tight, 1 in cylinder 1 and 1 in cyl. 4. my prob was i adjusted them all turning the motor 1 time and moving to the next cylinder. after reading if i recall you turn the motor twice before moving to the next cylinder.
just a thought
+1 on the valve lash adjustment. Since you took the rocker assembly off to get that valve fixed, it needs to be readjusted.
I can't read...
check these first...i'd bet a dollar that your spark plug wires are on wrong.
Curious George
just a thought
if they were too tight it will start, but it will make intake or exhaust back fire, run like shit, not run on 1 cylinder. It doesn't look a mecanical issue. 90% is something electric.
1 - 20 of 33 Posts
