1 - 15 of 15 Posts
Ok guys here the issue. my 1994 civic EX w/D16Z6-sohc vtec is running alot better after cleaning the IAC valve out. however now it runs ok and all it just has a searching idle. as soon as you come to a stop the idle will fluctuate from 550-1500. after about a minute it will come back to normal idle. but cant figure it out.
Maybe its the PCM? IAT?
Thanks
also car has new plugs and wires-no vaccum leaks I see
Lurking... ಠ_ಠ In Your Thread
ES1 Civic
do you mean "surging"?
ES1 Civic
have you toyed with the throttle cable?
have you taken the valve apart on bottom of throttle body? mine had came loose on the inside, made mine surge up an down...opened it up, screwed the internals up tight, and put it back on, perfecto.
no I havent messed with the one on the bottom of the throttle body. Also havent messed with the thottle cable either.
How andwhich way do I need to adjust the throttle cable?
Also how do I remove the lower idle valve?
Thanks
Thanks for the info-I think my issue is the FITV. may just need cleaned
any ideas where to start looking for vaccum leak?
Could the FITV being bad create a vaccum leak? thought I read that on here somewhere when searching for my answer
Thanks for the information. it is very helpful man
Rep for you
I will definiteyl check into it tomorrow and hopefully it fix my issue
could be it since it has like 151,000 miles on it and previous owner not too good about maintenance like that
yeah just take those 3 or 4 gbolts out of it, then take it apart, and you will see a thing in there that fits a wide flat head, tighten it down.
Definitely will do that tomorrow. I think that is my problem there and that it diod have a dirty a$$ IACV that I cleaned.
Also runnning my 1999 civic Si for the first time tomorrow-hoping for high 12's
1 - 15 of 15 Posts
