1 - 17 of 17 Posts
so i have a d15 1995 eg 4door... car ran but i decided to do a tune up.. so i replaced my spark plugs spark wires and dizz capp.. now when i finished putting everything on the car started and ran really smooth..i tried to start it a week later now it doesnt start?? any idea?
Have you checked to see if your getting spark?
1993 Honda Civic EX
When a car cranks but wont start there are 3 things you wanna check for : Fuel, spark and compression.
First of all check all your fuses. Then check fuel and spark first as they are the easiest.
ministry of mayhem!
93 honda integra
its getting fuel.. how do i check if i have spark and compression
spark.
1. get a screwdriver and someone else.
2. take the spark plug wires off. not from the dizzy.
3. take spark plug wire from cyl. 1 and put screwdriver at the part that goes into the spark plug. make sure there is contact between screwdriver and the copper connector inside the tube.
4. find a suitable metal part in your engine bay. that will be your ground. making sure you're not touching any metal part, place the screwdriver a couple centimeters above the metal part.
5. ask your partner to crank the engine, and check for spark. repeat on the other wires as well.
in order for a compression test, you need a compression tester.
i dont think i have spark... but i just put new spark plugs and wires.. but b4 i change it the car was running fine
ministry of mayhem!
93 honda integra
you don't think... c'mon dude you can do better. have you at least tested for fuel and spark??
ministry of mayhem!
93 honda integra
check cap and rotor.
B-series Destroyer
4g 4d civic
When you replace cap you should replace rotor.
1 - 17 of 17 Posts
