1 - 6 of 6 Posts
Ok so my problem is this, Ill be driving my 98 ej ex(5 speed) and then all of a sudden when i decide to let the throttle open upon (get into vtec mode so 5k+ rev) it will make a pop noise then my check engine light comes on and it wont let me rev past 4k. Sometimes when i do get on it though this doesnt happen it only happens every other time.
I recently replaced the crank and bearings, also has I/H/E, and when me and my dad where rebuilding the motor we needed a throttle body sensor so he went and got one from the junkyard from the same engine just different model car i believe it was. Anyway does anyone know or understand the problem im having.
I think i have to re-flash my ecu but will probably get a new one because if i have to because i will bee turboing it soon anyway.
Thanks for your time
here is the sensor that we replaced
Sidenote: it basically sounds like it has a rev limiter at 4k
Over 4k is overrated haha, I rarely go over 4k hell even 3k. But either firing order is screwed up or timing or vtec solenoid who knows. Double check them 3 an get back to us
What codes are you having when this happens? It will run with a bad MAP, it'll just go into limp mode and wont rev past 4k.
True didn't think of that, friend converted her hatch to obd1 an map was makin her go into limp mode a lot an would have to shut it off an restart car just to get out of it.
1 - 6 of 6 Posts
