1 - 10 of 10 Posts
take them out and get the free length
there is a reason the manual gives you this spec...
and not the installed height
its because the spring is limited by the retainers..so they are all going to be the same...
unless the valve is fucked up...or i guess the seat area
wrong. where did you even get this info??
when you cut the seat and valves the installed stem height and installed spring height increases. and if its not w/ in spec. it'll change the spring pressure and cause all types of nasty stuff to happen.
i'm not wrong if the original poster doesn't own up to his own modified valves or seats...
but fine...go on believing nobody is as good as you...
hence your need for a spec that can be mathematically achieved plus oem installed height...
1 - 10 of 10 Posts
