I want to get a skunk2 IM for my build and also want to get a larger throttle body. Professional products make a 65mm ITR throttle body for a good price. could I run that on my skunk2 IM for my d16z6?
yes plug and play, but It would only make sence when you borte the Im to 65mm
But 65mm would be too much for an d
The Great Weldini
i'm going to say this for the 760876769608x a Sk2 im has a opening of 62mm they don't make a 62mm only a 60mm and 65mm and up. a 60mm is fine but if you must get a Sk2 im. BBK tb are the only ones that make a 62mm unless you cans find a type r yb which will run you $200 used and $400 for a new ow. now try finding one cause it's like finding a needle in a stack of needles. a 65mm is way too much you might lose hp and may hurt your overal hp.
yeah if you have a skunk get the 62mm i got lucky and the skunk2 im i picked up on ebay came with a oem itr tb all i had to do was replace the tps
The Great Weldini
you cheeky lucky bastard, now that was a great buy/find, i will say.:bravo:
