1 - 20 of 23 Posts
I just bought a bare d15b7 block and it didn't come with main caps. Can I use the main caps off of another b7 or no?
racist-bigot-sexist-homophob
Check clearances and if all is well then run it.
will have to be align honed before clearances can be checked.
Basically the person just BOUGHT a paperweight.
See above...
Do you want this motor to last any amount of time? or just want it to get you through the next month?
05 Legacy GT
Read the direction on the plastagauge.
If you want this engine to last, you need to have good machine shop do a line bore. If your smart you will find a shop that will walk you through the steps they will do to your engine. Not just ask you what you want, take your money, do a ok job and call you to come pick up your stuff.
Didn't notice where your from, may be one of us could recommend a local shop for you.
Even if you check clearances it dosen't mean everythings going to be inline. You may get it all together and wear bearings prematurely or if things are way out of line snap the crank.
97 honda coupe
lol you guys would probibally crap yourselves when you hear what i did. camshaft from another head, and girdle from another engine Works fine and there is no bindage. The clearnaces were correct so there no reason i shouldnt have used them.
Cams no big deal, but I'm willing to bet if you pulled the bearings there showing more wear than they should.
maybie ten lol. i should have just shimmed the pump while it was out, but i didnt have time. now i do.
Yeah, that's what I was expecting. If it were 10K or so then it would be interesting.
Depends how everything's lined up. You may be lucky and everythings pretty straight.
1 - 20 of 23 Posts
