1 - 6 of 6 Posts
Just wondering...
it looks like my radiator blew up on 99 auto tranny Civic EX..
So I my buddy was offering a 95 Del Sol Dual Core radiator for a good price..
only thing is that the Del Sol Radiator is designed for a manual transmission..
can this Del Sol Radiator be used on my car?
Hondaphile
see above
well, there are tranny coolers built into honda automatic radiators. However a lot of the replacement radiators have the tranny cooler attached at the bottom regardless of whether you use them or not. I just replaced mine and it had one attached...not using the tranny cooler but it's there none the less. Actually had considered the idea of using it as an oil cooler........hmmmmm
vtec_concept said:
Just wondering...
DO NOT DO IT!!!!!!!!
You'll end up smoking the tranny fluid!!!!!!
Rule of thumb, for every 15-20 degrees cooler tranny fluid temp, tranny life is DOUBLED!
If you wanna run the Del Sol rad. your gonna spend about $60-75 adding a small tranny cooler + fittings. BUT your tranny will thank you in the long run.
Also with Honda trannys and non-serviceable filters, make sure you drain what fluid you can from the tranny and fill EVERY 15,000 miles.
I've got a 85 Accord with 172,000 mile on the auto trans, still shifts great.
I can vouch for that I've got an auto 91' Accord with 150k no problems always change the fluid every 15k!
Tranny oil cooler is crucial for any A/T the oil to water cooling method is extremely efficient try to stay with that. :werd:
1 - 6 of 6 Posts
