1 - 4 of 4 Posts
I have a 90 CRX Si that m not using right now (it needs a block).
so im going to get a new engine for it. but my question is can i use the crx head on my 92 civic cx. my cx is only a 8 valve so can i just swap the head.. and what do you recommend for my crx the same d16a6 engine or something else. i dont want to spend too much money on it. so if you guys can please help me i will appreciated... thanks
funny, I have a d16 just sitting around, too bad your not close.
alot of D-series engine parts are interchangeable, the head will fit on another d block, however if its dual point injection you'll need to do a multiport injection swap (theres threads on it all over) or keep your intake thats on your engine right now(which sucks) why you wanting to swap heads? more power? if so, you need to do the multiport injection swap or it wouldnt be worth swaping..
92 cx even with the 8 valve motor has multi point always from what i have seen. so i would give it a shot and throw on a d16z6 intake manifold on it also and you'll be rocking
1 - 4 of 4 Posts
