1 - 10 of 10 Posts
can i put the edelbrock turbo kit into a stock d16z6? it's going to be a daily driver so i'll just keep it at 6-7 psi. i want my car to last. do i need to change anything inside the engine such as headgasket, pistons, rods, get a block guard or sleeves? i want to slam on the gas once in awhile and not worry about the engine, and also i want this car to last like a stock factory car. so i want to know if i should strengthen my engine or is't strong enough for 6-7 lbs. of boost. i don't know much about cars please help, thanks.
the hard-parker
check out the turbo stickies at the top of the forum, but in a simplistic answer: no you don't really need to change anything. the edelbrock kit is made to run on stock motors.
you'll be fine bro, just make sure everything is up to par, and all the maintainence is good........ you shouldnt have any probs....... booost away!
oh yah last question guys. the edelbrock kit is made for stock motor is that means i can use the stock spark plugs and fuel injectors? or the i change my spark plugs and injectors?
1 - 10 of 10 Posts
