1 - 7 of 7 Posts
sub-sponsor
93 civic
k as some of you know im thorwing a zc head on my d15 in my hatch but it is dpfi so i need a si wire harness for my zc head, cheapest one i found was 100bucks but could i use a 90 integra ls harness in there? just thought wondering if it would work
SO you want to put a dohc ZC or sohc ZC on? Secondly, you want to convert to MPFI, correct? If you want to conver to MPFI, it is not as simple as taking an SI harness, and plugging it in. You need to spice some wires, jump some ECU pins, solder in a few connectors, mpfi intake mani, injectors, etc...
Check this site, they offer to do the wiring for you, I found a dude that fabed a whole sub-harness for me on ebay. It rocked to hell and back, and no worries. One less bullshit thing to deal with basically
http://rywire.com/store/product_info.php?cPath=21_27&products_id=63&osCsid=0f4a9716f672a78cbb963c17502a8c86
sub-sponsor
93 civic
the wiring wont be a problem i got friends who have done it before. i was jus wondering if the ls harness will work
They way it works, is really you are just using an LS harness for the injector clips, resistor box/clip, and a few other things..honestly, I'm drunk, so I'm out and done for the night.
According to rywire.com you CANNOT use a mpfi harness on a std civic. Its much esier to add thefew extra wires needed to you harness. Also dont put a dohc head on you sohc block, its will make you loose hp . THats ghetto.
sub-sponsor
93 civic
its a sohc zc. and its not a std. its a dx. you can use the si harness with modifications to it it will work
1 - 7 of 7 Posts
