Hey everyone. im new to this forum but not really a noobie.
i have a 99-00 civic D14Z2 that i turboed.
parts list:
ENGINE
99 Civic
Completely rebuilt ported and polished d14z2 1.4iS engine
T3 T4 T04E Turbocharger A/R .50 stage 3 Turbo 57 Trim Turbo
2.5 inch intercooler piping
K&N Air Filter
Custom Made High Flow Turbo Manifold
3inch downpipe
2.5inch resonator
Dual 2.5inch N1 exhausts
External Tial 38mm Wastegate
Greddy BOV
custom modified pistons but stock rods ( waitin 4 eagle rods)
Cheap ass ebay Manual Boost Controller
AEM Fuel Pressure Regulator
Stock Injectors ( for now)
Front Mount InterCooler
NGK Spark Plug Wires
Bosch Platinum +4 spark Plugs
MSD Coil
Turbo Head Gasket
SUSPENSION and WHEELS
17inch Monsoon Rims
Eibach Adjustable CoilOver Kit
Full Stress bars and Sway Bars kit
KYB AGX adjustable Gas Shox Kit
Cross Drilled and Slotted performance Rotors
Performance brake pads
Braided Stainless brake lines
Reinforced Chassis
ICE
Pioneer DEH-P9800BT Radio
Tsunami Power Capacitor
Infinity Reference Series 600watt 2channel Amp
Sony Xplod 1200watt 2channel amp
Rockford Fosgate 4channel 900 watt Amp
4 300watt Pioneer Speakers
4 200watt Tweeters
2 12inch 1000watt Xplod Subs
APC side mounted Boost Gauge
Remote Controlled Full Undercar neon Kit
Dual Halo Angel Eyes with eyebrows
Carbon Fiber front Grill
Hood Scoop
Mini Turbo Timer
Short Shifter
Carbon Fiber Side Mirrors
Spot Lights
I think i got off to a pretty good start. here comes where i need you insight. i havent really done much internal work besides new pistons. I NEED TO GET A CAMSHAFT!!!! not such an easy task for an economy engine ( d14) . since i know that so far my engine has been compatible with parts for the d16 engine, i'd like to know if an exospeed non-vtec camshaft for the d16a6 will work on my d14 since they are in my opinion similar besides displacement wise.
Bisimoto ftw..... There is nothing better for the Single cam
ur rite christopher, the turbo lag is ridiculous. i have plans to change the turbo altogether or simply change my rear housing. the downpipe i have helps a lot but i still get boost around like 4k RPM on 1st gear which is silly considering the work i've already put into the engine. would recirculating my bov make that much of a difference?!?! i have to say also that im being conservative since i havent done much to the internals. my wastegate is set to 6 or 7 psi only.
and also to SOHCinWA and cryz2, thx 4 the insight. i'll try it and see what comes up. but u guys trust bisimoto more than exospeed and cranecams ?
