1 - 15 of 15 Posts
Specs:
- D16z6 fully built minus sleeves
- Bisimoto 2.4 cam, JE 9.0:1 compression pistons, Scat rods stock length.
Question: When my car was tuned we retarded cam timing by 2 degrees, my tuner thinks we could have made more power if we kept pulling the timing back, but was worried about clearance issues as I never clayed my motor or degree'd my cam. This was my first build and didn't even know about claying at the time. I didn't degree it because a lot of guys were just dropping in the bisi cam so I followed suit(regretting this heavily now). How can I figure out how far I can safely retard my cam timing now that everything is assembled?
Going for a retune with Jeff Evans soon, and want to sort everything out before I get there. Thanks in advance.
wow danz, i'm so glad you brought up locking VTEC, that never would have dawned on me. was thinking about taking it back a degree more or 2 and hand cranking it...off to youtube i go to learns me some claying.
yea, that much i knew. I think I may just set it back to zero and degree the cam properly, then go see jeff. Atleast I know i can retard 2* without messing anything up.
out of curiousity, what are some common retard degrees people run on D series motors? what would be considered a lot i guess is what i'm asking.
hmm what would be a lot? thats tough to say
if i was probing on the dyno i might try 2 degrees either way and see what happens with the curve... then take it from there!
Toyota AE82
With some engines you can "clay" with the head intact.
Use thick solder and put it down the spark plug hole. But I think it will be a problem with a D series?
"I dont think you'll have any issues retarding it more than 2...unless this is a higher compression piston with oversized valves?
I've gone to minus 8 before on a Zex 59300 cam on a Vitara/Eagle combo and -6 on a Wiseco 8.5 piston with Eagle Rods.
Hell I've single cam turbo setups come in OFF 2 teeth on the cam in either direction and not had any valve issues."
this is what the homie from xenocron tuning told me.
i'm thinking i should be safe around -4* I don't think advancing will net me more power as we saw gains from going retard. What would be the upside to advancing danz? this cam advance/retard is something I'm totally lost on as far as why you make or lose gains.
i'm probably wrong, but i thought these were non-interference.
chris also mentioned the wiseco set up as well.
thanx for looking out danz, not really sure why chris woulda made this suggestion then...scratches head..
Honda Civic and CRV
I have a Wisco piston and Eagle rod setup, 8.5:1 comp and stock head. Had the valve timing gear skip a tooth plus the 4* already adjusted and no valve issues. Not that moving the stock cam timing really makes a difference, so I've found.
At one point the ignition timing was off by 12* and it still ran, daily! I'm brutal....
1 - 15 of 15 Posts
