1 - 20 of 23 Posts
Sloppy Jalopy
how did that happen?
was it hard to turn the camshaft?
fat chance getting it out ,start looking for a used cam, cuz if you have to pay someone to take it out it will cost more than a used cam would.
you're proper fucked now, cam needs to come out and you can try walking it out with a punch or getting a new cam
Last time I had a bolt snap in something portable I took it to a local machinist and he only charged me like $20 to remove it. Might be worth taking out the cam and driving around to a couple machine shops and asking.
Fail boat
its fixable for sure but the cam needs to be removed in which case it should just be replaced
props for showing pics of the Fail cause I woulda kept that shit to myself
D-series SoCal Division
93' dx hatchback
This has happened to me a long time ago. Go buy an easy out kit and it'll come out easier then expected.
Yeah I was turning it to the right and right before tdc it broke, is this a non interference motor?
just a heads up, you can quote multiple people in 1 reply instead of making multiple.
pet peeve. and the head of the bolt may be 12mm but what size is the actual bolt?
Its a 12 mm bolt
Fosho bro, umm I have a question, I put the block tdc using a screw driver, I was trying to put the tdc on the crank pulley, I don't have the plastic cover showing the arrow to march up to the pulley , so how would I do it ha
No its not. The hex of the bolt is 12mm diameter.
The bolt itself is M8x1.25.
8mm.
Alright
if the plugs are out, he should be able to do it... breakover torque on a d16z6 should be less than the torque spec on that bolt :lol:
lol, he doesn't know compression. when I was a kid, I loved summer. as an adult, fuck this shit
Reactions: transzex
Discussion Starter #20
.....maybe you shouldn't be doing things that require you to touch that bolt
Seriously idk what u fuckers are talking about but if ur trying to troll for ahead am a still post shit n talk shit , I just asked some questions n if thy bother u then get off my d n don't reply
1 - 20 of 23 Posts
