1 - 2 of 2 Posts
hey people,
i torqued my cam cap bolts to honda spec of 16ftlb and the thing wouldnt budge at all.
slacked all the bolts off and it span nicely.
re-torqued to 10ftbl so i could do the clearances and it span nicely.
im using a comp 59500 cam in a Z6 head.
any idea why it binds at 16ftbl? ive check that i have the right shaft.
cheers.
luke.
Original cam caps?? If so, take the caps out, clean the journals and re-assemble. Check for any burrs on the edges of the caps and ensure there are no burrs on the bottom surface of the caps so they sit flat against the cylinder head.
1 - 2 of 2 Posts
