1 - 4 of 4 Posts
recently changed cam belt on my d16a9 twin cam.tensioned up to what seems right but after a few hundred miles it seems to slacken a bit on right hand run looking end on.runs fine not jumping so i tightened it up again and again after so many miles its slackened off again.i dont want to over tighten tensioner bolt and strip thread.do they kind of find theyre tension ive had no trouble other wise
did you do it per oem instructions?
i have workshop manual cam lock kit etc,was replacing after a failure so had to re time but otherwise yes.engine is still running fine after prob around 1000 miles.ive left the cover off so i can keep an eye on it,i ll have to re tension when i replace cover anyway as belt has to be removed to put rear cover on
did you replace the spring for the tensioner while you were in there?
by this time its probably a hard part to come by.
but should be replaced at the same time as the timing belt and tensioner
1 - 4 of 4 Posts
