1 - 10 of 10 Posts
ok, i have a d15b2 with mpfi and i believe i have an a6 cam, but its hard for me to see a difference. anyways, got it in with the y8 cam gear all timed up and running, but my question is if it were another b2 cam would the y8 cam gear throw off timing enough for it not to fire? thanks
1993 Cobra
it will be off by a half a tooth on the gear using the B2 cam with a Y7/Y8 cam gear. D15 Block is shorter than the D16 block. But it should still start, just run like crap.
people are going argue this, but I had a y7/y8 cam gear at one time. placed a 88-95 cam gear over top of it and they where exactly the same. the timing marks where in the same place and everything.
what timing marks on the y8 sprocket are you using? 7 o clock or flush with the head? NM you have to be using the head marks. Y8 motors using the head marks stock right? not 7 o clock like a6's z6's??
Y7/8 cam gear CORRECTS the 1/2 tooth error because of the 5mm difference in deck heights.
1993 Cobra
I know it corrects it, I was stating IF he was to use the y7/y8 cam gear with the B2 cam it would be off.
yeah, that's the theory.
I really don't get this whole thing. if you milled the head, or had the deck flatten, etc. and the distance between the head and block is smaller, more compression, yay. but how would that cause the timing to be off.
if you put the bottom end at TDC. and the cam timing in the original position. the belts just going to be lossier. ????
ok, its still on stands, but it runs and sounds good. when i push the pedal it reacts well so i guess we'll see when my suspension shit is dealt with. any rusted bolt secrets? rusted all the way through the bushing tube
93 integra ls b18c
pb blaster, heat, impact.
1 - 10 of 10 Posts
