1 - 20 of 33 Posts
Eg Sedan
How many miles does your Vitara build have, what size turbo, hp/torque numbers, fuel, and amount of boost you were running? What oil and weight? Remember as a daily driver will help answer my question. I am seeking the answer to find the average mileage a GOOD tuned boosted Vitara setup has lasted. I know MANY factors other than the ones I listed above really affect engine life.
I have tried googling to find my answer. Even with searching this specific site.
-Average mileage Vitara build "d-series.org"- Which only shows results from DSO. This is just one example ^
If you have seen other threads related to this please link me to it.
Mileage:
Turbo and PSI:
HP/Torque:
Fuel and engine management:
Oil brand and weight:
Daily driven?
Black/Green Civic HB
40k
T25 ( off Sr20) @16psi
(Eagle and vitara y8, milled to 9.5:1 w/ stock z6 cam)
91 and free crome!
Should be 230-45hp 210-220tq
Run 10w-40 in winter and 15w-40summer
DD for 2yrs now and no engine problems, just other stupid stuff.
Avg. 30-37mpg
95 civic coupe
Mileage: 2500+k
Turbo and PSI: 18psi
HP/Torque: 301whp 262ftlbs.
Fuel and engine management: 93oc. Crome
Oil brand and weight: whatever shop had 10-30
Daily driven? It was might see street from time to time after the rebuild
95 civic coupe
Mileage: 2500+k
I really like your build and its extremely close to what i want.
Eg Sedan
Same here. My goal is 300+ hp on 93.
Supertech valve springs
Titanium Retainers
Delta 272-2
Precision 680s
Possibly edelbrock intake manifold... we'll see
Z6 block with eagles/vitaras 75.5 block bored to match pistons with .005 p2w
A6 crank
OBX lsd rebuilt to quaife specs
Tuned on modified crome program
'92 CX Twincharged D
Mileage:6k miles
Turbo and PSI: Twincharge, SC14 and He351ve, 30+psi, usually DD w/ 20 psig max.
HP/Torque:246hp/226ft-lbs. 15psi @ time on Dyno, have to drive 200+miles to dyno latest tune
Fuel and engine management:Crome Pro 1.6.9 R2
Oil brand and weight:5w40 T6 Rotella
Daily driven? Yes @ least 300mi/wk.
Stock Y8 cyl. head ported and polished w/ Ti retainers and race springs.
Y8 block bored 75.5mm w/ A6 crank and ported y8 oil pump
300lph walboro Fuel pump 1200cc inj.
OBX LSD Si trans
So far, a 100% stock OEM block with oem head bolts can handle what you all have posted up.
Someone post up some decent numbers or track times plus mileage!!
My civic
Mileage: 5k
75.5mm Vitara with Custom rods. -15cc
8.51:1 CR
Turbo and PSI: 15g
HP/Torque: 262/278 @ 22.6 psi @ 5k.... major break up above that.
HP/Torque: 245/233 @ 17 psi still with break up...
Fuel and engine management: E85 Crome Pro
Oil brand and weight: M1 10-30
Daily driven? All day.
When I can get these timing issues sorted out, I should clear 300..... dont know by how much with my 15g
Mileage: 30k
Turbo and PSI: Garrett 57 trim 17psi
HP/Torque: 313/271
Fuel and engine management: 94oct - S300
Oil brand and weight: 10w30 mobil1
Daily driven? Was dailyed before me, abused on the street and track by me.
95 civic coupe
Mileage: 30k
HP/Torque: 313/271
What cam are you running?
95 civic coupe
Thanks i had fun on that set-up, but there's couple changes on this next one. It should be close if not more
Mileage: 10k on a fresh d16a6, eagle/vitaras heavy milled 8:1, crane turbo cam, miniram manifold, 3" dp/exhaust
Turbo and PSI: Garrett t3/t04b (.60/.63) @ 22psi
HP/Torque: butt dyno is thrown off by all the tire smoke, never dyno'd
Fuel and engine management: 94 pump, Turboedit street tuned
Oil brand and weight: Mobil1 0w-40
Daily driven?: Every single day, no issues.
Mileage: 35k
Turbo and PSI:Hx-35, 15psi, 24, now 30psi
HP/Torque: Pump 93 350hp 300ftlbs, 24psi 408hp and 350ft/lbs, now 500hp/450ft/lbs
Fuel and engine management: Ectuned, tuned by the man JD
Oil brand and weight: Rotella
Daily driven: Was DD for all those mile minus last 100miles as race car.
IF your trying to build a strong running DD that will last stay away from vitaras!
The way I used to see vitaras was, they would handle as much as the stock sleeves would hold. I DO NOT see it this way, WAYYYYY to many crack vitaras in the last 2 years locally and the forms.
Vitara motor= crank boost, make power, enjoy, POP! All in that order ahahahah
1 - 20 of 33 Posts
