1 - 18 of 18 Posts
93 eg coupe
I have chosen to mic my rod and main journals on my d15b7 ,and not just relying on plasti gauge to find my oil clearances.
I'll be using telescope gauges..
My main question is does any one make a vernier caliper that is accurate to the
.0001 or better ?
All I've found is .001 accuracy
Micrometer is fine if I have to ,but I'd like the versatile of 1 fits all kind of measurement tool. 0-6 inch
Thanks
1996 Civic Type DX
Not that I know of. I use a micrometer when I need accuracy.
Telescoping gauges aren't going to be much better than plastigauge. You need to use a bore gauge, you'll need a micrometer to use it with.
93 eg coupe
Thanks guys
I have a digital 0-1 inch micrometer that has a accuracy of .00001
I'll use that for bearing thickness
Dial bore gauge ,1-2inch micrometer should do the trick
Aquafina I'll be giving you a call for LSD after engine is assembled.
93 del Sol Si
Don't forget about setting the bore gage correctly if you really want accuracy. Otherwise all you'll have is a relative measurement because of the variance in the indicator mounting position when setting it up. Using a bore gage setting tool allows you to set the desired result with gage blocks, then transfer it to the dial bore gage to your desired accuracy with the mounting adjustment. Once you've done that, there's absolutely no guessing as to how much under/over the desired size you are via direct reading of the dial.
Also, remember if you're looking at dial bore sets to get the resolution you desire... most of the cheaper sets have .0005" resolution instead of .0001" resolution. The range of most sets will be 2"-6", although I've seen some that are 1.4"- 6".
.0001 or better ?
Thanks
I'm sure someone does. Try goodson.
93 del Sol Si
Looks better than .001
maybe there will be more accurate
Did you not check my link?
Fowler's new Bore Gage Setting Master Kit is
used for accurately setting any bore gage up to 6"
in diameter to an accuracy of .0001".
Granted, you have to get a bore gage that can be set to the tenths to have that accuracy, but that was why I mentioned to watch for the desired degree of resolution in the post.
Here's a nice set on Ebay that would cover the range you're looking for.
And another one...
93 eg coupe
Thanks for the help
Telescope gauges are useless in the I need accuracy department category then .....right?
Dial bore gauge is the best option ....
I could see my self spending a fortune on measurement tools.lol
97 honda coupe
.0001 or better ?
Thanks
a caliper to measure something in the ten-thousanths range?
Im not sure if your going to get a good reading with even a digital caliper, there is simply so much that can change those readings at that small of a measurement, hell the heat from your hands warming up the tool can change your readings at that point.
1996 Civic Type DX
Yes, telescoping gauges are useless for accuracy and you will spend just as much on the proper tools as you will on the engine build itself.
93 del Sol Si
Right...
Dial bore gauge is the best option in a reasonable price range unless you're planning to use one day in & day out. There are much more expensive options if you're flush... Triga-bore
A fortune, indeed! Best value is likely to watch Ebay for quality name brand equipment at decent pricing... I've seen Sunnen bore sets with the setting station go for under $200 on occasion!
I used telescoping gauges to assemble a bottom end once. Took about 4 times as long as it should of cause you end up checking each measurement 6 times. Picked up a fowlerr dial bore gauge after that. Mine is graduated in .00005"
93 eg coupe
Discussion Starter #18
kool
Makes life easier for sure thanks for the insight....
1 - 18 of 18 Posts
