Boost Gets You Laid
Del Sol
So the piston in my caliper seized and I went to replace it; Now a new issues has risen.
The bastard is stuck to the top caliper slide bracket. It will move up and down but won't slide off... Starting to get pissed off.
Suggestions por favor.:cussing:
as long as ur replacing the whole caliper than its cool to heat it up, but I wouldn't do it if you only plan on rebuilding it
loosen the bolt, remove the bolt and caliper, not that hard really.
Likely just dirt on the end of the slide pin bolt give you fits......
Boost Gets You Laid
Del Sol
It was actully rusted on. Ended up having to reorder a loaded caliper with the bracket on it.
I got the caliper off the old bracket by center punch and hammer.
