1 - 20 of 32 Posts
00' Honda Civic EX
so his b2 tranny will work on a DOHC ZC & a D16A1? Just bolts right up...?
B
transzex said:
Right, how do you figure?
Please explain why it is better.......if you can.
:mikej:
Yes I can. With a HD PP the cable stretches more then with a stock PP wile shifting giveing you a better chance for grinding gears with quick shifting. Can you tell me why I'm wrong??
D-series Janitor
Front Engine Dragste
BoogieDown said:
Yes I can. With a HD PP the cable stretches more then stock a stock wile shifting giveing you a better chance for grinding gears with quick shifting. Can you tell me why I'm wrong??
In my limited knowledge, I have yet to see anyone use a hydraulic setup over a cable setup for a transmission outside of the honda people when dealing with a performance enviroment.
So if you could clear that one up for me, that would be great. I am trying to figure out why my friend's Tremec TKO 600 doesn't have that option . . .
B
If your car has a cable tranny get a cable. Apparently from what Transzex says it doesn't matter and I would take his word over anything I have been told. On the other hand it does make sence, then again who am I disgree with someone that knows 100x more than most of us???
1 - 20 of 32 Posts
