1 - 17 of 17 Posts
89 hatch
my 89 STD hatch has had some work done. Running a B7 stage 2 cam, multipoints, intake etc..(long list) -it's alot faster then stock. I swapped in a 5sp from a 90 CRX with a eclutchmaster stage2 clutch, PP and lightweight flywheel. The PP barely clears the BH, but we muscled it all the way in and I guess it fits. Been driving it.
This trany is going out. It was weak from the start. Noisy, I started a thread on the clutch noise a while back but we found out the clutch is fine. Its this tranny. I need a new one. eclutchmaster rocks! They got back to me every time I had a question. It isn't the clutch at all.
Should I get another cable tranny from another 90-91 CRX Si? or do a cable to hydro conversion with a 92-96 CRX Si tranny? If so what do I need from Hasport?
Do I need
EFDHC?
and the mount kit??
EFSTK?
Will another cable tranny hold?? what'ss the best gear ratio if I can save $$ and pick up another cable tranny 88-91 :3dtard:
HASport kit maintains the clutch cable, definitely the best conversion. Most kits make a pedal bracket with a slave dont they?
The HASport unit bolts under the hood somewhere, and uses a lever with the cable
sadly, its more expensive alone then even one way overpriced cable SI tranny
you can easily mount a clutch master on a bracket under the dash and actuate it with the stock pedal.
thats what i would do if i was in a pinch.
or just go cable. i almost prefer cable over hydro... hard to say...
ministry of mayhem!
93 honda integra
Friend of the D
It's definitely not the best conversion! The only real benefit of a hydro trans is when you are using a heavier than stock pressure plate. A cable won't hold up to the abuse of some of the really heavy clutches. Hasport's solution is half assed at best IMHO. If I were to do a hydro conversion, I would want to do it right and use a new pedal assemble, master, and slave set up. There is a new peddle assemble available. After that, I would use Innovative mounts.
Suja1
I do. I think you get more feel from them. (although stretched cables are a bitch ;))
Suja1
The HASport kit im talking about has a boix that mounts in the enginebay
inside the box is a clutch master. you maintain cable clutch pedal assembly, but gain benefit of running a hydro trans without having to modify or add anything to the trans itself
the cable is run llke that since the radiator sits right behind it.
I think its a clean way of adding a hydro. No pedal bracket assembly to replace. just a different tranny mount, and any braided clutch line to top it off.
Friend of the D
89 hatch
You've all given me some good ideas, thanks. I'm in the N. Cali, Mendo/Lake area. I'll probably drive to Sac at the end of the week and try to get a 91 Si cable trans. Of course I cant take my hatch since Sac. is a bunch of zero tolerance sell outs!!! CARB is a never ending collective of bureaucrats trying to keep them self's employed...
(Breathe deep)
I'm OK now.
Yes, a new cable Si tranny is what I'm getting.
Friend of the D
Actually, the part you show in your picture Matt is the part that Innovative sells.
I see that Hasport has introduced a similar cable to hydro set up as well. I guess the original set up didn't work all that well ;) It's got to be better than just attaching an arm and cable to your hydro trans.
89 hatch
Discussion Starter #16
I got a 90 CRX Si cable trans from Specialized Parts Planet in Sac, Cali. Great folks! Fast shipping. The trans is tight, looks like low miles. The gear ratio is way closer then my old 5sp. The noise went away, however I STILL have a high speed front end vibration. I am at the end of my ropes here!!! The whole front end is new; poly bushings, new rack. everything is new. I'm thinking a bad axle, but it is new!!(From Kragen) which is why it might be bad... I dunno. I'm about to start yet another thread..
peterbilt
all ill say is cable ratios are way way shorter my ej1 is slow compared to my zc pwrd 90 fodo
1 - 17 of 17 Posts
