1 - 6 of 6 Posts
any thoughts on this it is a very audible sound like a constant droning buzz coming directly from the CAI tube, I have a the intake for 1 year now and have never noticed this sound before. Thanks alot
nonvtak ftw
without actually hearing the sound i can only guess it the same one i hear and it actually is caused by the IACV port in the throttle body. depending on the intake i run on my car it can be pretty loud.
ok, for some reason it just sounds really loud to me, i just put on a new header gasket and changed the plugs, but i don't think those would have anything to do with it. So you think it's nothing to worry about??
Lurking... ಠ_ಠ In Your Thread
ES1 Civic
is it loose? did you use some type of hardware to tie it down or hold it in place. my guess is no. you just have it on there and when your throttle is open its hitting the shock/strut tower or vibrating against your distributor.
no its an actual audible sound when the car is just sitting there and you can hear it directly coming from the filter
1 - 6 of 6 Posts
