1 - 16 of 16 Posts
hey i have a boosted d16 y-7. its a turbonetics setup with stock internals. my problem is that when im at idle i notice its been smoking blue a little bit. how can i tell if my seals are letting oil past them or not. other than that the car runs perfect. thanks
try a compression test check what numbers u have ;;;;;;;;;if its a new turbo hardly its the seals but do the test first find out if there is internal problems
did compression check and had 150psi all the way across. the motor has only been boosted a month and this just started about a week ago
whats an oil restrictor? drain is good, nice smooth downhill drain. the oil feed line is just the -3an braided hose with a 90deg. bend fitting. so i dont think there is a restrictor
my turbo smokes a little bit sometimes, its because i don't have the best drain or a restricter :lol: its a cheap turbo and i'm going to completely change the setup soon, so i'm not worried about it.
anyhow, if i were you, i'd check into getting a restricter. Honda's have way too high of oil pressure for most turbos.
Yeah I would get a restrictor, that would be a guess to the problem.
FAMILY MEMBER #316
so what if you bought a kit and it was made for a honda? should you still get an oil restrictor?
1 - 16 of 16 Posts
