141 - 160 of 387 Posts
'93 / '95 Del Sol Si - '95 DX Coupe - '00 Accord EX F23 Manual
Discussion Starter · #145 ·
Yeah, who knows what’s wrong with junkyard motors. This yard does have a 30 day return policy though, and realistically I could bring in a battery and compression tester and find out before I pulled/paid.
https://flic.kr/p/2jbDj1E
https://flic.kr/p/2jbBZAj
Here’s what I picked today. Some blanks to replace the two I bought that were the wrong color. I also found a sail panel to replace my cracked piece, and a knee bolster cover to replace the one on my car that had a few holes drilled in it. Also found the firewall harnesses I needed. I already spliced them together, so now my tuck is essentially plug and play. I also grabbed a spare IAT sensor and a dash vent for my RDX.
Discussion Starter · #146 ·
https://flic.kr/p/2jczDia Swapped out the blanks for the right color
https://flic.kr/p/2jczDi5 Got the passenger bag back out and the tray back in. You can also see my DIY harness down on the floor. It reaches and it’s plugged in. Still haven’t cranked the engine to make sure it works
https://flic.kr/p/2jcCn5W Cold air intake is back in. Will test fit the bumper as soon as I can. Tested my headlight tuck harness and everything works. I did not test the rad fan yet but will when I fire her up this weekend
Discussion Starter · #147 ·
https://flic.kr/p/2jdLWwE Polishing up the headlights, for the third time. The one on the right is done, the one on the left is not. Both are hazy inside, so not much else I can do short of cracking them open again. Will probably just buy a clean EDM pair and be done with it.
Discussion Starter · #148 ·
Went to start the car tonight and nada. Well, shit...will be troubleshooting this weekend.
New clutch slave cylinder should be here next week. And word on the street is the MVA is open by appointment only so I’m going to call tomorrow and get the next available Saturday slot. Wish me luck
Discussion Starter · #150 ·
Okay, she starts now. Really helps if you install the trans ground! Still waiting on parts. Still haven’t made an appointment to get title/tags. Right now I’m just doing little odds and ends until I get my RTA bushings. I moved my O2 sensor from runner 4 to the bung before the collector and it hits the CV boot hard. Logical options are get a new header, have a new bung welded on the header, get a test pipe, or put the sensor back on the runner and use an O2 extension harness. Anybody out there got a used 4-1 you’d like to sell me?
P28 is back in the car and I’m running the Hondata D16Z6 map. Need to hook up the laptop and set base timing. But first I need to buy a timing light.
Discussion Starter · #152 ·
Blox test pipe ordered today.
I’m starting to inventory my Z6 parts to figure out what I need to buy to get that assembled and swapped in. I have a complete long block, FJ rods, Vitara 75.5 slugs, and a Cometic head gasket. I’m looking to add an ATI Super Damper and I still need bearings/thrust washers and the machine work. And I’d love a Canton oil pan.
Discussion Starter · #155 ·
Thanks man. I’ve got nothing but time lately, so why not be OCD. End goal is to build/buy a harness with OBD1 ECU plugs so I can ditch the jumper all together.
And I finally made an appointment for title/registration for July 22. I might actually get to drive this car before summer is over.
Nice. I just got a Blox test pipe myself.
As far as free time goes, I usually do the work as quickly and efficiently as possible these days...and then creep back out into the garage between midnight and 6 am to get all OCD and tidy everything up. Kinda' sucks working like that. But it's the only way I can get stuff done.
EDIT - Mail is moving so slow, dude. It's insanity. I waited a month for a cam that was shipped Priority 3-Day...And have been waiting about two weeks on average for other stuff.
Man, after looking through your pics of the yards and such, I decided that I need to come out west, buy a hatch, fix it enough to drive home and start building from there. I'm tired of buying cars that "just need a little rust removal" to get them looking decent.
Discussion Starter · #159 ·
I’m actually in Maryland now, I just haven’t figured out how to change my avatar. I never even went to a junkyard when I lived in Arizona since I didn’t need any parts then. It’s tough finding clean body parts out here, but I’m looking about once a month.
https://flic.kr/p/2jjv8Hy Test pipe is in, still have no room to squeeze the O2 sensor in there.
https://flic.kr/p/2jjqXwa So I just moved the sensor back up to the header. I’ll figure this shit out later.
I started her up today and the number two runner wasn’t getting hot. So I pulled the plugs and number 2 hasn’t changed color like the others. So I’ll be working on that next lol. Probably something simple. Fingers crossed
Oh, dude, I didn't know you were in the salt zone now. Damn. Now you feel the rust belt pain. Some surface rust on a panel doesn't seem so bad now, eh?
I had my o2 in my test pipe for a while. I was able to squeeze it in there carefully and screw it in. After it was in, it had just enough room for "bounce"...What o2 are you using?
Clean as hell underneath, man. That's impressive for the east.
