Head: D16Y8
Cleaned, checked, 3 angle valve job
Supertech Valve Springs
Supertech Titanium Retainers
Bisimoto/Web Level 2.4 Cam (Rated for up to a 80HP Gain over stock!) - almost $500 by itself after shipping!
All new manifold studs and nuts
ARP head studs
Blue valve cover
Block: D16Z6
Cleaned, decked, bored, honed, and notched
JE SRP 9:1 Ceramic Coated top/Teflon coated sideskirt custom pistons
Eagle H-beam rods
ARP Rod Studs
ACL Race main bearings
ACL Race Rod bearings
Melling Oil Pump
New OEM water pump
Gates Racing Timing Belt
New OEM Timing Belt Tensioner w/spring
Completely new OEM gasket set
I have over $4800 into this between the $3500 in parts along with over $1300 spent JUST on machine work, cleaning, and assembly. Everything has been assembled and torqued to spec by the same machinist.
All paperwork will come with the engine
Engine has never been installed or fired up. Still has assembly lube on all parts. The only thing I have done is put it on an engine stand and mock up my turbo to it.
I am asking either $3000 for the engine or $1000 for the head and $2000 for the block. If you are located within ~100 miles of Upstate/Albany NY, I will can help bring this to you. Extras like the exhaust manifold, turbo, etc. are also available and will be put up for sale in future posts. Thank you
ARP head studs
Blue valve cover
Block: D16Z6
Eagle H-beam rods
ARP Rod Studs
Melling Oil Pump
New OEM water pump
