1 - 4 of 4 Posts
Hey i got a delsol it idles weird and spits nd sputters when you barley touch the throttle but goes away once u get past like 1300 rpms but still idles weird like its turnining off every quarter second ive had the car but havnt drove it much due to this issue I've notice the builds a little rigged there's no evap control canister and all the vaccum lines are just pluggged off with a screww i have a video of it idling mayb i culd get some opinons idk much about theses jdms but i gt tge car cheap and jus tryn to grt it running right here's the video thanks
http://m.youtube.com/?#/watch?v=xXN57iqHFUw
Couldn't view video, net connection sucks where I'm at right now.
Sounds like a vacuum leak by the text of it.
I appreciate the input I'm pretty sure the vaccum lines hav somthing to do with...plus i dnt even think the vtec is hooked up right or hooked up at all
I agree it sounds like a vacuum leak how you describe it, but the video didnt work for me. To help pin point the source of the leak you can spray short bursts of brake clean around the intake manifold and lines and when the idle changes you found your leak.
1 - 4 of 4 Posts
