1 - 17 of 17 Posts
Did anyone build their turbo setup, tune then build their head afterwords? if so how mild or amazing was the build and did you notice the difference? a lot or not at all?
i boosted on a bone stock head, now i have crower 2 turbo cam, springs/retainers, il let ya know after i get retuned.
93 Legend L Coupe.
The more air that you are trying to cram into an engine, the more work the engine has to do in order to cram it in there. Stock heads CAN put out a lot of power, but as soon as you get the head sorted out with proper porting and a good for the application cam, you will make more power on less boost, showing a great increase in efficiency. It is not uncommon to make 50+WHP with 4lbs less pressure over a stock head/cam, at least when you are dealing with 350+HP setups. Again, this is really dependent on the competency of the head porter and cam designer.
2000 civic 2 door ex
headwork with a cam goes a very long way :)
awesome. bisi cam plus some head work:smartass: will def go a long way. hehehe:yes:
headwork and any turbo cam, will go a long way.
I wanna do a bisi 2.4 cam. buuuut it says professional use only. and HAVE to use the bisi valve-train.... gaaaaaaaay
93 Legend L Coupe.
There's plenty of info available if you search for a while. I answered that question witha couple hours of googling and reading. There are several before and after dyno charts available on other forums/websites.
Well?
why are his upgraded srpings gay? thats all you need. The 2.4 just needs to be tune professionally, its a big cam but its not that big. the 59500 is bigger
The Man, The myth, The legend
2003 Cadillac Esc.
Actually the bisimoto 2.4 is quite larger than the aformentioned cam. I personally measured the differnetials myself.
Can i use the bisi cam with another spring/retainer combo?? :wacko:
Car would obv be dyno tuned by a good tuner :bigok:
2003 Cadillac Esc.
Yes, you can, as log as you check for coil bind with the intake vtec locked out, and they are very good windings to prevent float.
Yeap. I will be running 1 early next yr. 2.4cams, your valve springs and retainers.
Then PnP with portflow. ") Hope it will show great results. :)
1 - 17 of 17 Posts
