1 - 15 of 15 Posts
What will I have to do to get away with revving my 20psi boosted d-series to 8000rpms as a DD? Will have eagle rods/srp pistons in the bottom end.
I've searched but havn't found any results to my liking. I just wants to know whats required, machine work, whatever. Just help me out.
· R2.....Zap Balls
94 Ex coupe
the main thing you'll need is to make sure you get springs and retainers that can handle that rpm. I think stock are good to right around 8,000, but I'd upgrade to be safe.
See above...
I'm currently running a stock valve train up to 7800. It's not like I'll hit that all the time, but when I do I have no such problems... But if anything, I'd just upgrade that cam (stage 1 only, anything higher and you'll need to upgrade springs too)and the retainers. Assuming just 8k revs. But if I had the $$$, I'd of course get the entire valvetrain.
· yellow bar for me
viper blue 92 eg
i would atleast upgrade springs and retainers to reduce valve float at those rpms. cam isnt necessary to make 400 hp. but it will help it be more efficient and make those numbers at lower boost levels.
Honda
i know what valve float is, but how do you know when it happens? is there a sound that the valves and rocker arms make????
also, can valve float be catastropic to the motor?
just curious
thanks
Honda
drunkinmaster is making over 400 on the stock z6 head and revving it to 7800...
i plan on running a skunk2 cam which has huge lift, but small duration. Skunk2 says it is okay to use with stock valvetrain, would you go past 7200 with stock valvetrain?
thanks
See above...
IF I remember right, the Skunk2 cam is just a "stage I" cam... Usually those are fine to run with stock valvetrain. And if they say you can do it, I'm sure they tested it as such. At 7200, you should be fine...
with that much boost id go the route of better safe then sorry if i were you, valves, springs, retainers and a good cam
im building mine up because the rev limiter gets hit every now and then in autox and i dont wana be f'in things up and im only boosting to 13lbs tops
i have the skunk2 valvetrain, and i've been well over 9k :)
when the head was stock i shifted at 8k all the time at 10 psi and it held up. but i'm a crazy asshole :lol:
1 - 15 of 15 Posts
