1 - 7 of 7 Posts
d-series 007
95 hatch si
ok im starting a new project here are my plans
d15b8 block: encludes pm3 flat top pistons, crank
d16z6 head: encludes dizzy, intake manny, exaust manny
z1 timing belt
d16z6 tranny
any recomendations on anything i should do or use?
C
I would try to get an aftermarket clutch at the same time. ACT stage II or clutchmasters stage III.........You dont want to start up a new project with a stock clutch and then have to pull the gear box again just to put in a clutch.......
I would alos upgrade the exhaust to 2.5 inch at the same time......
I see the basics as cold air intake, header, exhaust and clutch... With this alone will will have a nice running car......
peace
C
You could also get an upgraded computer to rev a little higher.....
peace
d-series 007
95 hatch si
update on the project
ok so now i have
d16z6 head (shaved .037) i shaved off the thicknees of the head gasket, i was planning on 2 plying the gasket but i dont think i have the valve clearence to..
with the head shaved at .037 i'm looking at having 11.2:1 comp (using d15b8 block w/ pm3 flattop pistons)
tranny is d16z6 trans (looking into getting lsd for it but not sure about spending $900 on it)
Also for the project i bought new :
6 puk clutch and extreem presure plate (working on getting light flywheel)
full catback exaust
4-2-1 header
p28 ecu (i just ordered jdmsh!t race chip) from jdmshit.com
and an adjustable camgear
later plans: full rebuild on the head (skunk2 everything)
hopfully ill have it done and driving in the next couple of weeks..
when i get it done ill snap some pics and post them up
d-series 007
95 hatch si
sure will ill have pics up in about a week, well maybe 1 1/2 i need to have the car detailed
1 - 7 of 7 Posts
