1 - 9 of 9 Posts
Hello
I have a 92-95 Civic CX/VX
USDM Hydro S20 A000
3.250 1.761 1.066 0.853 0.702 3.153 3.250
but i swapped the engine with a d16z6 but that tranny just makes me want to sell the hatch. So a friend offered me a tranny and after opening it and counting it i got 4.058, thats the only one i counted
but here is the problem
mines is P20 A000 in the circle by the vss
but the one i bought says e5f p4a s40
and the circle by the vss says P4A/A000 AND THE vss from this one is different to mines. mines have the vss and have like a metal piece holding it with 2bolts< this one i bought have the vss with no bolts and just a screw next to it.
and here is the other problem. the one i bough( for 50$) is broken on the side that attaches to the engine and have another piece broken which i don't know the name in English.
What i want to do is take everything from the broken tranny and put inside mines, replacing the broken pieces with mines.
i want to know what you guys recommend me to do because i dont know. IF DOABLE AT ALL( an di hop eit is) what gears should i be using or swapping to get the best tranny i can out of these 2
ahaha
and sorry for my English i know its hard to read :(
i think the tranny i bought its actually a 96+ tranny and thats why it haves s40 on the sticker and why it haves a different vss but i don't know im new to this.
in case i cant put all the inside of the broken tranny on my pice of shit tranny , i can also buy the broken piece of case from another friend.
now im really confused, i manually counted
5th 0.702
3rd 1.172
2nd 1.782
i think is this one D16Y7 2000 Civic Coupe / Sedan
1st gear Ratio 3.25
2nd gear Ratio 1.782
3rd gear Ratio 1.172
4th gear Ratio 0.909
5th gear Ratio 0.702
Final Drive Ratio 4.058
That Y& tranny is fragged, I wouldn't use anything from it except maybe 5th gear.
Where did you get the info for the 92-95 CX tranny???? There is a slight typo, 4th is .852, I made that typo 10+ years ago to see how far widespread my info would be used.
Myself, I would search out a D16Z6 tranny, P20/B000 and keep your current CX tranny as a backup.
Swapping the gears is possible, but not easy
i wanted a d16z6 but getting a tranny here would cost a fortune. non v tec for around 250 and vtec for arund 450
thats why i wanted to work on that one since it was just 50$
it'll still suck, just not as bad.
Where is here, your location????
Other newbs take heed, he did his research!
puerto rico,
people sell engines and transmissions like they are made of diamond
actually I have 3.0 04 accord engine with a cl type s 6 speed tranny with lsd with hasport mounts and axles waiting for an ecu and tranny shift cables, but i was planning on buying a cheap hatch/car without engine to swap this one in and then work this hatch with the 3.0.
But i feel like i been taking a wrong decision after another :(
we have a few members on here and other "like" forums from PR.
eddcartes for one.
Shipping parts to PR is cheap thanks to USPS :)
well how much will a d16z6 tranny cost +/- in the US?
i found one here for 350 but says 92-95 vtec, going to call later today or Monday
mines suck, i look like a 12 y/o learning to drive manual each time i have to accelerate from 0.
ty for helping me :)
i was expecting something like gtfo you noob with 1 post learn to google lol
Shipping parts, not a whole tranny. It is $300+ to ship a tranny to PR as it is over USPS 70 pound limit.
hello again
i just wanted to let you guys know i went ahead and this the chage, they looked a little different in the inside but i changed all the gears and everything came out nice and it works without any problems. Now i actually use 5th gear and can go up hills in 3rd hehe. although it said a000( long shity gears) they are actually pretty good. I got the gear ratios manually and they were these:
3.250 1.909 1.250 0.909 0.702 3.153 and 4.058
but for 50$ i cant ask for more ty for your help
1 - 9 of 9 Posts
