1 - 13 of 13 Posts
I got a promoted! And I'm PINK!!
any comments or suggestions on parts?
ill have 10 months to build, 10 months from june when i can get my licenes back, and when i can start working on cars again.
Rough List of plans.
Current State
Car: 91 CRX DX ED8.
Engine: None
Tranny: None
Suspesion: cheap-o coilovers
Interior: Stock for now, No seats.
Plans
Engine/Drive Train:
-OBD1 DOHC ZC
-Endyn Block Post kit(debating, since i am goign to run aroudn 20psi)
-LSD ZC tranny
-Performance Integra Axles
-Custom Head Gasket
-Hondata Style Intake Gasket
-6 puck Clutch
-ACT street lite flywheel
-JGE Camshafts
-JGE Valve train
-Eagle Rods*
-SRP D16a6 9.5:1 CR pistons(9.1:1 in dohc zc)
-ARP Head Studs*
-ARP Main Studs
-ARP Pressure Plate bolts
-ARP Flywheel bolts
-1000cc Presion Turbo Injectors*
-P29 ECU*
-Homemade Turbo manifold(or SLS Log manifold)
-t3/t4 Turbo*
-Ebay Intercooler*
-3" DP & Exhaust
-JGS precision 40mm wastegate
-JGS precision Bypass valve
-JGE Adj. Cam Gears*
-Alum. Half Rad.
-OEM GSR Dual Bend Shifter*
-Wideband Oxygen Sensor
Suspension/Brakes:
-Ex sedan Front 10.3" Brakes*
-Integra Rear Disk conversion
-Stainless Steel Brake Lines
-Full Bushing Upgrade
-Anti-Roll bars(sway bars) upgrade
-Home made Traction system
-Full Coil Over system (Function & Form or D2)
-Integra Booster and MC*
-15X8 Sportmax rims, black/w polish lip
--either 002s or 501s
-Camber Kits
Interior:
-NRG quick release and wheel
-6pt Roll Cage
-Roll cage Camera Mount
-Racing Seats(not sure on what kind)
-Various Gauges(boost*, EGT, Oil Press.)
-Dash Mount Gauge pods
Exterior:
-EF Side markers
-Amber Corner Lenses
shotting for a min. of 250whp.
Notes:
*=Bought/Recived
See above...
ARP making you custom mains? Tell them to keep the measurements, mass produce them, and sell 'um...! Though I've never heard of anyone complaining about the OEM ones.
Worst Mechanic Ever!
EG
Do you have money to blow, cause that could buy other nifty goodies. I think it's good to go OEM where OEM works, these after market companies love you buying shit you don't need.
Hell, half the reason I love honda is because you can build them up with OEM parts as well as aftermarket parts...
EG
I know, I was just saying. Looks like a sick build, whats your HP goal? Is this a drag car or a road car?
EK 96
keep OEM parts the are tuff strong for about 300 whp and even higher in some cases
1 - 13 of 13 Posts
