1 - 7 of 7 Posts
Hi guys ive a D15b2 all stock and i want to put it mpfi.
i know b7 has only +10hp its ok its 11% more power.
I can get b7 manifold and ecu easy.
wondering what more i need to be like a b7. dizzy is diferent?
Camshaft is diferent? will one of these make the same work?
and what about the resistor box?
97 honda coupe
waste of time, without going the extra mile.
Your going to need a new ecu and run 2 more wires to the ecu for the MPFI conversion. PM6-8 will work for MPFI. Pm8 will run lean though, just a caution.
Get an a6 cam and throw it in there as well and i would suggest before your doing any of this to swap it over from auto to stick (if it isnt manual allready).
Depends on if you want to stick with OBD-0 or convert to OBD-1.
For OBD-0 you will need a6 injectors, a6 distributor, and an mpfi obd-0 ecu like a pm6, pr4, or pg7 for example. Along with a resistor box + plug, 7 pin distributor plug, and 4 injector plugs.
OBD-1 you can keep the b7 injectors, b7 distributor, and not need a resistor box. A b7 ecu will also work fine, but you will need to pick up an obd-0 to obd-1 adapter harness. The o2 sensor will also need changed to a 4 wire, and the distributor plug will also need some splicing.
The b2 cam is the same as the b7 cam.
1 - 7 of 7 Posts
