1 - 4 of 4 Posts
S
Right getting some parts to gether for the boosted d15b7.
Quick thing though am in the uk and wondering what would be the equvilant of the manifolds used for a HMT setup.
HF, in uk = ??
Is there anywhere i can get adaptor plates on the net, still not sure on the turbo, most likely a T25 or T3. I would like to have to not weld the adaptor plate!!!!
Last one, i heard through the grapevine i can use prelude injectors, is this true and what engine, H22? 310cc?
Only going to be runing about 5-7psi so stock ones should be fine but just want to be safe!
Cheers
Lifetime Awesome Member
i cant really tell ya what the equivilant in manis would be...
but for adapter plates, look here http://www.homemadeturbo.com/forum/index.php?topic=25834.0 or here http://www.homemadeturbo.com/forum/index.php?topic=34894.0
as for injectors, for probably the same price as the Prelude's , you could pick up a set of DSM 450s(around $50-$60), and they will be good when you turn up the boost more. and i say "when" you turn up the boost, not "if" because you WILL turn it up, its inevitable. boost is addictive
this is true i turned mine up until it blew LOL 17psi on d15 non vtec rods wont handle more then 15psi.
O
Having a turbo car that's turned down to only 6psi is like handing a crack addict a a huge crack rock and a tiny little pipe and telling them, "now dontt smoke more than once in a while..." Yea RIGHT!!!!!!
1 - 4 of 4 Posts
