Hey all,
I just received a new to me D15B VTEC and one of the vacuum nipples on the throttle body is broken. I had difficulty searching this because I don't even know what the thing is called:
How are these attached? Are they threaded or pressed or what? Can you buy new ones somewhere or just pull off a different engine. I'd like to use the stock throttle body as I plan on keeping everything as stock as possible. How would you all go about fixing this thing.
Thanks!
braze it, yank it, or replace the whole assembly
Meat Popsicle
91 CRX Si
I suppose you could drill it out, tap the hole, and find a threaded to barb fitting. Otherwise a quick and easy way to fix would be to cut it/break it off and run a self tapping screw into it with some kind of sealent.
If you want to keep things nice and OEM, find another TB.
Thanks for the responses guys. :)
So if I wanted to go the route of tapping the existing throttle body, I could just look for a generic thread-to-barb fitting that could hold a vacuum hose? Am I understanding this right?
Is there any difference between a Z6 throttle body and the D15B VTEC throttle body? The one on my current B7 definitely looks different and has some different vacuum connections. I googled pictures of the Z6, but it's not obvious to me right away.
Discussion Starter · #8 ·
Okay I did some more research, unless I'm mistaken D16Z6 and D15B have the same throttle body and intake manifold. Sorry, should have looked a little bit harder.
I guess I'll try to find a fitting that works for the throttle body I have... I suppose I could go to the junkyard and look for one too.
