1 - 10 of 10 Posts
I was pulling out of a parking spot this morning in reverse, and when i put my car in first and released the clutch it clunked a little and then popped out of gear. I put it back in gear and tried to take off and the car didnt move. Now the tricky thing is that the speedo works properly when i hit the gas. So i am guessing the diff is ok but perhaps the spider gears are broken. I did not get a chance to check the axles yet but at a glance they seemed to be in place. The car shifts into all gears and feels normal just doent move.... Any Thoughts TRANSZEX ????????
FAMILY MEMBER #316
wouldnt it have to be the axles?
yup, you owe me $10 green hornet, pay up sucka!
How much noise did it make when it popped????
How much noise in 2nd gear at idle???
Wait till you come across a 88-91 diff pin in a 92 tranny.......Z6 tranny I built with a Cusco last sunday.....had to use a backup case.
Discussion Starter · #8 ·
Thanks for your help guys, I jacked up the car and the passenger side axel Did pop out of the trans. Never seen that happen before. Always something isnt it
1 - 10 of 10 Posts
