1 - 9 of 9 Posts
'92 civic, '96 SS
ok so heres the problem. I have a 92 civic with the stock d15b7 in it. About a month ago the timing belt broke. I finally got enough time to replace it about a week ago. After i did i cranked the car up and was letting it idle. It ran for about two minutes and died and wouldn't crank back up. So after messing with it for a little while i found it wasn't producing any spark. So my dads friend, who's a mechanic, came and looked it over and after checking the distributor with a voltmeter said it was the ign. module. so i changed it and still nothing. The distributor is only about 2 years old, its what was wrong with the car when i bought it, so i'm now at a loss. any ideas would be a great help.
Also what are the torque settings for the rod bolts on a set of eagle rods?
Thanks Chris
90 DX
Make sure the cap/ rotor is cleaned off or new, and if you switched out the module, try the coil next...
92 civic hatch si
Most times it's cheaper to just replace the whole dizzy as a unit.
was it a oem unit?
'92 civic, '96 SS
Well the cap is clean and i put a new rotor on the same day, i forgot to mention, so idk. i'm going to try using another dizzy i have and if it works i'll just go get another one. the one i'm going to try is for my d16 so i can't just keep it on there
2003 Jeep Rubicon
check the lil metal wire connection's on the ing mod. this happen 2 me they were just loose an my car would just shut off. I also had the same problems you had. No spark an a dead ing mod.
are you throwing any cell lights?
1 - 9 of 9 Posts
