1 - 7 of 7 Posts
91 CRX Si
I repaired & reinforced mine twice before I bought a new one and added a hush performance cable to hydro bracket for reinforcement.. repairing my original one lasted a good while each time but its a pain to remove it and fix it every so often.
If you don't have too heavy pressure plate I'd say just repair & reinforce the one you have
CRX ECODiesel Ram
Discussion Starter · #4 ·
Exedy sport clutch so not heavy at all. If i can find the bracket in the junk yard it's $25 and my buddy will weld it stronger for free. Probably weld this one up too at the same time for a spare. I have a fresh synchrotec trans with mfactory fd and lsd...
Huh, I didn't even consider the pedal bracket to be an issue. I suppose this would be a good preventive maintenance item for stiffer clutches/super high mileage cars.
CRX ECODiesel Ram
Discussion Starter · #7 ·
well the two closest pick a parts had nothing so unless i get lucky i get to try and get geometry back in shape and get a buddy to weld the crosspiece back, repair the torn up sheet metal and then add material to get it stronger and better.
1 - 7 of 7 Posts
